ThrlSkr
I dropped my '06 on its right side a few weeks ago. Using Xtra long frame sliders, so there was no damage to the fairing. On the way home i stopped in traffic and smelled antifreeze. Coolant was overflowing and the temp needle was in the red. As long as i was moving, the needle stayed normal.
This bike has overheated 3 times on me since i had it. Twice in stop n go traffic in the dead of the summer. Once because of a bad radiator cap.
Long story short, i got it to the shop and they cant find anything wrong. checked the cap, water pump, replaced both the Tstat valve and radiator switch but it still leaks antifreeze.
They checked with Suzuki tech support and are now suspecting a bad head gasket.
Can anyone shed any light for me here? I am the second owner of this bike and it only has 13000 miles on it. Services regularly and ridden responsibly. So far im out $600+ and they dont even know what is wrong with it . . .
They are hoping that it is only a gasket because if anything is cracked i will need a new motor . . .
Thanks in advance
Thanks in advance
