should have been working on the bowtie motors when they went to the reverse flow cooling systems.. we had everything from bad air locks to guys putting the wrong water pumps on the motors.. was a disaster..I have a Mustang that exhibits the same overheating symptoms if not burped correctly. Very easy thing to miss if not well-acquainted with it. Do not assume shop guys are well-acquainted with anything.
CW
You said it over heated 3 timess. So it is possible that it has a head gasket problem. Aluminum engines dont take over heating very well. When I am trying to find a head gasket leak that is putting pressure into the cooling system here is what I do. Make sure the cooling system is full and the engine is cold as in hasnt ran over night. With the radiator cap on start and run it about 20 -45 seconds no more than that then remove radiator cap if there is pressure at the cap then there a good possibility that there is a head gasket leak. You must get the external leak found and repaired for this to work. You didnt say if the fan runs when it gets hot. Does it?
I'm not a technician but wouldn't the coolant mix with the oil if the gasket was shot? If thats the case, just look at the oil and see if its changed to a milky type substance.
Turns out, the second opinion (second shop) is that he needs a new radiator.........I think all he needs is a new cap, but hey, whatever calms the cooling system down, and gets him back out there !!!!
Our boy is back in action....sure hope he sticks around !!! :oldcool:
precisely.. in many cases however you will have the sweet smell of burned coolant out the tail pipe (very distinct) and also a plug check will usually show a spark plug in the same hole that looks spotless new while the others show some carbon build up (coolant makes a great decarbonizer)It could also leak directly into the cylinder without getting into the oil passages, but that should be noticeable in the exhaust or at least with a couple rev ups you will see black water spots hitting the driveway.
any approved methods from GM for aluminum rad repairs?Make sure to get the old radiator back. Then take it to a radiator shop and have them test it. Sometimes those radiator shops can repair them easily and cheaply. Which would give you a backup radiator in the event of a wreck or something.
