JohnnyDangerous
Sorry the pic didnt come out, hopefully will help
I would imagine its all stock, should I add preload as a stop gap till I get heavier springs/oil?At 210-220lbs
You are at the limits/over stock fork springs.
You should have more travel left than that.
If you do have correct springs, your setting is not correct.
Yes, I'm suprised there is any left.I would imagine its all stock, should I add preload as a stop gap till I get heavier springs/oil?
Fork springs rated for your body weight including gear is a must.So increase the preload then but what would a permanent proper solution be? Springs or what?
Add all the preload it will take. Proper solution is to change the springs to one that matches your weight and then add preload to reach proper sag levels. Might as well upgrade the valving and shim stack since you are in there. It will be a whole new beast after that.So increase the preload then but what would a permanent proper solution be? Springs or what?
Exactly what I did...works great.Add all the preload it will take. Proper solution is to change the springs to one that matches your weight and then add preload to reach proper sag levels. Might as well upgrade the valving and shim stack since you are in there. It will be a whole new beast after that.
So am i looking for less lines or more on front preload adjuster? Stock is 5 lines showingAdd all the preload it will take. Proper solution is to change the springs to one that matches your weight and then add preload to reach proper sag levels. Might as well upgrade the valving and shim stack since you are in there. It will be a whole new beast after that.
Surely screwig it in ie less lines applies more preload to the springs? Or am i missing something?More lines showing.
Basically wind it clockwise slowly till it stops, then back it off quarter of a turn.
Thank god thought i was going mad !!!! Gonna try set up bike tomorrow.My bad, sorry...
It's early and only had one coffee..
Clockwise = less lines showing.
Apologies. Still waking up
Less lines. Screw it in for more preload. Go all the way in then turn it back out a 1/4 turn.So am i looking for less lines or more on front preload adjuster? Stock is 5 lines showing
I think it's DOT4, it should say on the MC cover(just make sure you use the right one), any brand synthetic is fine, as it lasts longer.Thanks dude, ive done zip tie trick many times, I have a mytevec vacuum pump and suction, any fluid recommendations?
