thank you. I'll begin by re-torqueing the header bolts before removing the gaskets. would you be able to confirm the torque spec for the header bolts please?I'm going to say this issue is being over analyzed. Take your exhaust headers off and take out the crappy gen3 exhaust gaskets. Install the gen2 exhaust gaskets and test again. Especially before you start to diag the engine in any way. If you didn't re-torque the 8 header bolts at your first oil change as instructed by the Suzuki service manual then I would 100% start there.
thank you. i will order new gaskets from the dealer and look at this.I did 18ft lbs but the service manual calls for a little less. The factory gaskets are copper and crush once and they don't seal right. The gen2 are a normal material used on automotive gaskets and are more forgiving.
Keep in mind when you remove the gen3 gaskets, use a flat head screw drive, get behind them and it takes a little amount of force. It almost feels wrong removing them. I only had 600 miles on my gaskets before the Brocks kit was installed and removing the factory gaskets was unsettling.
Look at this? You got a picture? Didn't post.thank you. i will order new gaskets from the dealer and look at this.
Pfff. Mine has sounded like that since 0 miles after riding for a few miles. Still bothers me, but what am I gonna do?
Hayabusa 2022 engine clicking noise at idle on a hot engine. Can hear this click click sound every time after a 15-20 minute ride on idle.
Consistently makes this noise on idle after a 10-20 km ride.
