TheEmeraldBiker
Picked up a great deal on a brembo rcs 19 brake and clutch master cylinders. For anyone else running a brembo clutch master what have you guys used to still keep the clutch switch operational?
Some members, myself included, have used a hydraulic pressure switch that replaces the banjo bolt at the MC. In my case, I had to cut some of the threaded end a bit to get it to “bite down” on the crush washers and line, but worked great. I believe I saved the packaging in my parts bin for reference in case I ever needed a replacement. I could search for it, if nobody else has the info handy. I know @fallenarch used a micro switch for his, because he had issues with the hydraulic one, so maybe he has some specs on the one he is using.Picked up a great deal on a brembo rcs 19 brake and clutch master cylinders. For anyone else running a brembo clutch master what have you guys used to still keep the clutch switch operational?
That's cool I have a spare hydraulic switch from another project, I'll try that when all the parts land in n and see how I get on!Some members, myself included, have used a hydraulic pressure switch that replaces the banjo bolt at the MC. In my case, I had to cut some of the threaded end a bit to get it to “bite down” on the crush washers and line, but worked great. I believe I saved the packaging in my parts bin for reference in case I ever needed a replacement. I could search for it, if nobody else has the info handy. I know @fallenarch used a micro switch for his, because he had issues with the hydraulic one, so maybe he has some specs on the one he is using.
Bypassing the clutch switch changes the map.I've seen a lot use a 16 but the 19 master cylinder is listed for the busa on brembos website. I haven't received the kit yet but i don't think the kit came with a clutch switch. I've read before that bypassing the original clutch switch only causes issues and throws up an fi light..
The 16 provides a clean feel of the clutch whereas the 19 felt a tad heavy when releasing and pulling in the clutch. I spliced in a switch instead of a pressure banjo switch.
I have a spare 16 that came off the LE as I upgraded that side to a Brembo Billet M/C.I went the 19, and didn't like it. Ended up going back to stock m/c.
Now living in the spare upgraded parts pile, I have no use for it as the GSXR runs cable clutch and the second K8 is being left stockish.A spare Brembo 16 clutch side you say??
In the same country as me...
Go on...tell me more
Hmmmmm........
Comes with a Brembo Titanium Gold Pivot pin.
Open to offers lol.
No worries , have a few spare so yell out if needed.Hey Doin,
Welcome from a fellow Aussie from Melbourne..
Good to see you here.
Awesome write up, love the idea.
I'm on the hydraulic at the moment and, touch wood, havent had any issues..
But if I do, guess who I'm contacting for a switch setup
Top effort.
Stay safe
