That's the attitude that got you into this mess to start with. If you are not mechanically skilled enough to know better than forcing a bolt in cross threaded until you twist the bolt off I have no confidence you can drill a stainless steel bolt that's as hard as a whoresheart out of an aluminum frame with a hand held drill without making a mess of your frame.
I'm leaning towards agreeing with davapors that just maybe you are in over your head. There is no shame in asking for help from a professional. I wouldn't take it to a bike shop, I'd go to a machine and or metal shop where they have all the proper tools and know how to get your boo-boo fixed.
Remember, that bolt is bound in the hole so tight that you twisted the bolt off. What makes you think you can twist that puppy out with a tiny little easy out which you'll probably break off in the hole even if you are successful in drilling the hole without touching the threads. Once you break the easy out I can guarantee you won't be drilling that puppy out.
Sorry to jump in like this so late but everyone here that has said carbide bits and the guy working on straight jets are right. I work on C-130 motors that operate at or around 900-1077-1083 degrees Celsius and there is really nothing that will not come unstuck or is unfixable. You can def fix this but be careful. Also, a tip for when you get it done; put ALL of the bolts in by finger first before you tighten. Once you have them all in then you can tighten them all up and the fairing will stay aligned. Good luck man!
Not taking my bike to a shop is not an attitude, its a preference. One thing I enjoy about doing everything myself (sometimes with the advice from others) is that I learn from life experiences and do not rely on always having to have someone else do something for me. My decision to force a bolt (whos only purpose in life is to hold a piece of plastic) is not a reflection of my mechanical abilities. As I stated before, I made a bad decision and knew while doing it that the outcome probably wouldn't be good, but also wouldnt be the end of the world. I took a chance and the outcome was as I expected. I find it interesting that a few people on this forum would rather insult my intelligence/abilities than offer advice as was requested in my first post.
I will take the advice of those understanding the situation and attempt to get the bolt tonight and will post results either way. If i muck up the situation any more, I will certainly let you know that my lack of mechanical abilities caused me to further complicate matters so that you can sleep better tonight.
My apologies if you took my post as an insult. It certainly wasn't intended to insult your intelligence. You simply made a bad call and it bit you. Lord knows I've had plenty of those in my life time.
I hope you can resolve this unfortunate predicament you got yourself into and it has a happy ending.
Cheers!![]()
Hindsight is 20/20, but there's no way that bolt was coming out with a standard easyout after being snapped off. I always prefer to drill up to the threads, in small steps near final diameter, to remover as much of the bolt as possible. Sometimes this weakens the bolt enough it can be be gently folded out of the hole. Worse case you remove some of the threads on one side of the hole, in which case the bolt can be picked out. But you would probably still have enough threads for holding the fairing.
Now your next step is a solid fix, but you might consider a couple options first. If you maintained centerline (maybe reinstall the fairing to check) when drilling/grinding out the bolt/easyout you might already be close to the tap diameter for a helicoil. That's a quick and easy fix. Otherwise i would look into a keensert, it's like a fat helicoil. OD-ID is typically 4mm, but they make thin wall versions too. You can buy them online, like McMaster-Carr, or at a specialty machine supply house. If you do go this route I would just remove the little stakes and thread lock in place to allow easy removal should the need arise.
Good luck, hope it all works out.
Glad you aggree it is a shame that I give him some good advise like take it to someone that does it for a living and I get flamed. But all these others can't seem to understand when to tell someone that they should seek expert advice on a subject.
They tell them stupid suff like this.
"Hindsight is 20/20, but there's no way that bolt was coming out with a standard easyout after being snapped off. I always prefer to drill up to the threads, in small steps near final diameter, to remover as much of the bolt as possible. Sometimes this weakens the bolt enough it can be be gently folded out of the hole. [COLOR="Red"[/B]][B]Worse case you remove some of the threads on one side of the hole, in which case the bolt can be picked out. [COLOR="Red"]But you would probably still have enough threads for holding the fairing[/COLOR].[/COLOR]
For all you idots that can't read and want to flam me please read . And I qoute the originaltor of this post.
"Here comes the stupid part... The last bolt i attempted to put in was the hex bolt in the center of the right fairing. For some reason the bolt would not go in straight, no matter how hard I tried. I made the dumb decision of trying to force it to thread the bolt in cross threaded, believe me, I know this was dumb
All I did was agree with him and that he should seek professional help
"No need to be hateful. The guy asked for help, not brow beating."
Listen guy I gave him much better advice than most of the other guys.
He does not need to mess up his bike listening to people like you.
rothman stated.
I have spent the last 9 years removing incredibly stuck, insanely hard hardware from fighter aircraft and their motors. Screws that have cycled through close to if not more than 1000 degrees hundreds of times.
this is the someone like he should take his bike too. And expert that won't mess his bike up. I'm sure he is allot better at doing this now then he was 9 years ago.
San diego Busa here is some good advice for you.
Call Joe @ 760 741-2673 Racers Machine in Escondito he will fix you right up.
Tell him I sent you.
Well the advice I gave was forsight that says an oz of prevention is worh a pound of cure.
I'm Sorry I gave you such bad advice in seeking out some like Rotman.
Just for future reference, a carbide drill bit will eat through an ez out with a little effort. Problem is that carbide bits are very expensive and not exactly something that most stores would stock.
How big is the hole now? I definitley suggest trying a helicoil before any kind of aluminum home-made solid insert.
