NCpanther01
another pic
that's what punisher suggested also when I called him.(Jester0769 @ Jun. 16 2007,15:03) yea, that sucks. Happend to me a few years back when I was Cali for the seca race. Ended up coming home and getting the thing Tig welded for 300 bucks.
what year is your bike. Is this a common problem across the board or just year specific?(Jester0769 @ Jun. 16 2007,15:03) yea, that sucks. Happend to me a few years back when I was Cali for the seca race. Ended up coming home and getting the thing Tig welded for 300 bucks.
LearJet, even with the case protector installed I need to have it welded? A moment of silence as I pray!!!!(Learjett @ Jun. 16 2007,19:44) You will have to have it welded back, no doubt about it or find another case. It was mostly common in 2002 models (which I have) but some other older ones as well. When that thing breaks it's expensive. It breaks because of a starter kickback under certain conditions. I use a YTZ14s battery (I think that's it), keep it on a tender, changed the starter system wiring to 4ga, and installed the ti ring for good measure. Low bat, hot bike, give it gas, .... and that's where you're most likely to have the problem. Lots of stuff on here about this. Sorry.![]()
Hey Punisher!(Punisher @ Jun. 16 2007,20:01) From what I can tell, I would go have a piece made up to be welded (again Tig, best I think for this) back to it. That should do you until you can decide if you want to replace the whole thing later. But a good fab shop should be able to do it for you. Again price depends on how much they have to do but for what we do at work I don't think too much would be needed.
P.
Goldenchild, please explain. I understand having to have it welded but drilled?(GoldenChild @ Jun. 16 2007,23:00) You gonna need it to be welded first then drilled for pin...This is not common but happens in 99-02 busa due to kickback.......
Roger that I understand now! I'll check aound here locally for a welder. Now I guess the next question is shshold it be made of steel or (fab piece)?(Punisher @ Jun. 17 2007,07:22) I think what he is saying is that, possibly remove the remaining piece and have a new boss welded in place? What I was thinking was if they take a piece of round bar, drill it out the right size, cut it to match the missing half. They can then weld that piece in place of the missing half. Our guys do things with steel like that all the time.
Whew! .......this one is really a sticky mess. Here's the kicker, even after you have it welded up, you need to install the TI ring OR/AND upgrade the starter system to an 03. Otherwise, another you're inviting disaster again. I did a LOT of things to mine to prevent this, and DO NOT give it gas trying to start a hot bike. Hope this helps.(GoldenChild @ Jun. 17 2007,02:00) You gonna need it to be welded first then drilled for pin...This is not common but happens in 99-02 busa due to kickback.......
