I would think the oil would simply fill the filter as you're pouring oil into the crankcase. The filter sure does drain easy enough when you are removing it.
In most engines just filling the crankcase won't fill the filter until the engine is started due to the fact that the oil pump must provide the oil to the oiling system.
