Fireman_on_a_Busa
A local motorcycle shop here in NC is in the process of testing a new belt pully system on a donated busa. It is a 3 layer kevlar belt, with steel strands, wrapped in rubber, made by Goodyear. The belt is rated for 200hp. The pulleys are original sprocket size,hardened steel, but can be changed according to what you want. My question is, would it be good to change to the belt drive. The chain lube is so messy, and extremely hard to keep the swingarm clean where it goes into the front sprocket. It is modestly priced, but wanted some advice. Hey that rhymed......
