orangebusa??
im thinking of it as its initial impact the revs create on the chain or belt which is whats at question hp and torqe is not when you think of an inline four cylinder compared to a twin there is more rotating mass the amount of force actually applied at impact of the engine tranmitting it hp and torqe to the clutch then the chain or belt then the tire and then the ground will be greater of course the clutch takes it first and the clutches job is not at question the next impact, and that may be a poor choice of words,of that higher rpm and rotating mass is the chain or belt the force will be much greater from the busa then a harley regardless of the amount of power each makes. once in motion that force on the chain or belt can be figure in terms of hp and torqe that the engine makes if you rev a motor to 2000 and let the clutch out the tires is going to spin but not as fast and with as much initial force as if you let it out at 4000 think of just one thing say a car that weighs 10000pds hit a line of water barrels at 30mph and a car that weighs 5000 pds hit the barrels at 60mph now granted the 10000pd car is going to drive further before stop but initial impact of the barrels will be higher with the with more speed now think of it this way the busa engine is heavier and faster then the harley hp and torqe aside the impact will be greater from the busa im kinda getting my self confused let me know if you see my point
