It makes absolutely no difference whether it's on the side stand or on the rear stand.
Easy way to set the chain tension without a measuring devise is to push up on the chain with your index finger about half way between the front and rear sprocket. If you can touch the chain to the swingarm without much effort, the chain is just right. If the chain won't touch the swingarm, it's to tight. If it slaps the swingarm without any effort, it needs adjusting!![]()
+1
And if it doesn't move at all, its too tight :blush:
