Cleaned chain today...
Hayabusa2005
A reminder to everyone to clean their chain good since it nearly spring. I have a 2005 with 2200 miles and it probably hasnt been done much. I used 5 cans of brake cleaner to get the chain where I could see the gold color in it again. Also, put the teflon lube on it...amazing it runs smoother! Cleaning chain help prevents premature wear.
i enjoy keeping the most difficult part of my bike clean. when i see other bikes i look at the chain to see if the rider takes care of it. its easy to just keep the plastic clean
Recommend kerosene, or even diesel fuel, over brake cleaner for a standard o-ring chain. The rubber rings seal the lubricant in the pins. Brake cleaner can get under the rings and attack the main lubricant.
+1 on Kerosene, works awesome with a plastic bristle brush. You can get it in 1ish liter bottles at wal-mart in the camping section I believe (Coleman brand). A heck of a lot easier with a rear stand as well. :beerchug:
O Holy P...that is my bike...2005...same color. I do not have the chain press tool, so I did not remove the chain. In the future, I will remove and dip in Kerosene. Thanks for the advice!
use kerosene, apply on entire chain while rolling around the sprocket, no need to take chain off, with a bristle brush, and then do it again. after the second time around your chain will be clean if you will clean it every 600 miles. I have 44000 miles on my 05 and on my second chain and sprockets, they always shine. :)
What is interesting is that I went to a Honda Motorsports dealer and ask for a chain degreaser. He told me to buy the Honda brake cleaner...oh well, I am going to buy a new chain soon since I am stretching soon. Thanks for the great advice. Learning a lot of this board!
I bought a can of cleaner/lube from the HD stealership (just cause it was the closest to my house)... anyone else use this? I might get some kerosene tomorrow...juuuuust in case.
I use Kerosene and WD-40, you can buy a gal. of kerosene at Lowes or Home Depot.
I use kerosene and a brush on the whole chain then wipe the chain down; I use Chain Wax on the inside of the rollers between the plates then wipe down the chain with WD 40 to prevent corrosion. The chain is checked and adjusted next. This process happens every 400 miles.I also use a piece of cardboard between the wheel and chain to keep the mess off the rear wheel and tire
Uhhhh....errrr....ummmmm....I can't be the first guy in here to notice something right ????:whistle:.....first of all, if you went through five cans you may have flushed the pins badly.....(I'm not banging on you, don't get me wrong here), but did you continuously spray the chain as you rotated the rear sprocket ?. If you did or didn't you still put a LOT of solvent on that chain. Did you allow it to dry for an hour or two after you wiped it clean before you put grease or kerosene on it ????.......the reason I say an hour or two, is five cans is a lot of solvent. Was the chain warmed up prior to greasing ?. If not, it barely made it by the seals, and if you didn't rotate the rear wheel, the pins probably didn't get much if at all........except solvent
The only reason I'm going long form is that you DO ride the fastest color, SO, that means I gotta help when I can !!!:thumbsup: Do you have a rear stand yet ?. If not, get one. They're nearly one of the most valuable servicing tools I own. Here are my basics for cleaning and greasing.
A) Warm up the chain by either riding the machine for a half an hour, or letting it idle in first gear on the rear stand for at least twenty minutes.(DO NOT go near the chain while it's warming up with any FINGERS, RAGS, or BRUSHES)
B) Either work in a well ventilated area, or wear a face mask, and use a fan. (See note below)
C) On the rear stand, spin the rear wheel and spray for about ten seconds while the chain passes underneath the swing arm. This allows the chain, pins, rollers, and links to become wet, but not enough to flush or drown anything. Now take a throw-away cloth and rub the chain while you SLOWLY rotate the wheel (watch your fingers now). I actually roll the chain in the reverse direction. That means, underneath the swing arm the chain is headed for the engine, and NOT towards the sprocket.:thumbsup:
D) Repeat "B"
E) Allow chain to dry for at least ten minutes minimum. This gives the leftover cleaner a chance to evaporate. If the chain is warm, what doesn't come off on the rag, will evaporate quickly.
F) Start spraying or brushing your lubricant onto the chain while slowly rotating the back wheel. Preferably, brush or spray the inside of the links so the sprocket teeth get their fill while you're getting those o-rings nice and wet. Rotate the wheel some more, and keep spraying or brushing. What we're trying to accomplish here is penetrating past the o-ring to the pin with as much fresh lubricant as possible, along with the rollers, but most of the time that's the first to get worked out after you start riding. Thus the rotating of the rear wheel as much as you can. This gets understated, and overlooked much of the time. Even after you're done lubricating, keep spinning that wheel, work that stuff in there.
G) After lubrication and penetration is finished, let sit for several hours (I leave it overnight). What's left of the solvent will evaporate along with the solvent in the grease leaving nothing but an abundance of lubrication.
Now, this is by no means everyone's "How-To", but I commute daily thus I do my chain regularly. A lot. I replaced my stock chain at 16,000, and I have 37,400 now. My ZZZ is still in excellent condition. I do, by all means, recommend if you're spraying chain lube on that you take a 5" wide piece of cardboard and slide it into the gap between your tire wall and the inside of the chain. I use a 5", by 24" piece. As I roll the wheel backwards, it gets stuck up top underneath the tail and stays put until I roll the wheel in the forward direction. It keeps over spray OFF the tire and wheel, and ON the chain where I want it to be. It also gives me an aiming point. I really milk it on. I also, after rolling the lubricant in thoroughly, wipe the edges and sides clean as at this point, the o-rings are well-soaked. I don't floss between the links though as this can remove more than you might want. I then let it sit overnight until the next day. No more squeaks, nor more link noise. Quiet and smooth.
The NOTE form above: "PLEASE work in a well-ventilated area, and if you're using a spray lubricant and spray solvent, wear a face mask" Now I'll tell you why. The Spud used to do his "winter" chain services inside the garage with the garage door cracked a couple inches. I inhaled enough of that stuff that it put me on my back twice for five days at a time. Those instructions and warnings are there for a reason. Even with a fan, I was drawing the vapor into my lungs, thus causing the toxic reaction. The vapor will cling to your lung lining. Whether I'm out doors doing the service or inside a garage, the door is wide open and I use the fan for circulation usually behind me.
For those using kerosene, the same warning applies, but the effects are much less aggressive. :oldcool:
Normally I complete the above service in less than 30 minutes on average, and that includes pulling the three phillips screws and the chain guard. I use Motorex 611 o-ring safe chain clean, and 622 heavy duty chain lube. I'm not a big fan of the kerosene service due to the ungodly buildup and intense cleaning necessary on the rear hub, rear sprocket, and front sprocket cover. No offense to anyone that likes the kerosene service, as that "is" what the manufacturer recommends.....
