1. Warm chain with a quick ride or run it in place using a rear stand or the 5/8" steel dowel rod/jackstands support.
2. Clean with kerosene (you can get a 5 gallon drum from Lowe's that will last you a lifetime) and use grunge brush or any other combo of tooth brush or plastic brushes and rags - tooth brush gets the sand out of smaller areas missed by the thick bristles of the grunge brush. Don't forget to clean the rear sprocket teeth as well. Also, kerosene evaporates where WD-40 leaves a film and is a degreaser so then trying to add chain lube is IMO counterproductive to an extent.
3. After kerosene evaporates run chain again to warm and loosen and then add chain lube.
