I think most missed the fact that the temp was rising "until he turned it off" yes, they go into the red at that point.. as long as the fan is cycling, the thing is not overheated..
Turning off a hot motor means you LEAVE IT OFF for a good period of time so it can cool.. Turning off an already slightly heated motor will make it overheat..
I did not see where it had boiled over or was blowing coolant out (typical of a motor that IS overheated).. Gauge readings are not all that reliable and so you kind of have to rely on the fan cycles to indicate a real problem.. (mine indicates hot when it is not boiling)
point being if you turn off the bike because it is hot, you best leave it off for an hour or more before restarting it..
Great point noted and taken.
