OK,
Bear with me. I'm one of those mechanically uninclined individuals, but I managed to do oil changes, plugs, and air filters many times on my VFR.
Now, I'm looking at the 'Bus, and it's new. So, I'm intimidated. Particularly because so much of the fairing looks like it needs to be removed.
(And yes, I missed CiscoSanJose's "How to" last week... I was moving!)
OK, looking in the manual, the first thing to do is to remove "screws and fasteners" on the black plastic "frame cover" thing. On of them I can deal with (has an allen head), the other is a black plastic flat thing that looks like you jamb a screwdriver under to pop up. Yes? And is this piece really related to removing the fairing?
I think removing all the "regular" fairing screws looks pretty straight forward... except perhaps you remove the screws to the bottom, tail fairing thing(where the centerstand would go) ???
Are the screws on the underside of the front (by the radiator) those plastic screws that melt just by touching a screwdriver ?
My biggest question is this... does the fairing come out as 1 gigantic piece? Or is there a left side/right side?
What about the new (for 2000) "bracket" that seems to hold the lower together?
Any quick input on this will be appreciated.
Whoops, one last thing... I'm assuming I can walk into an auto parts store with my Suzuki oil filter ($14 OTD !!!!!!!! HOLY **** !!!) and just find a cap to plug into it so my 3/8 can drive it out?
TIA.
