ecu editor auto shift
nappinj12
does the new ecu editor have auto shift, and will boostbysmith air shifter cable work that way, i have the cable now, useing horn button. would be cool if it autoshifted too.
ECU will not autoshift...at least not yet. If you buy the shift light from Boostbysmith, you can connect the output to the solenoid and then be able to horn shift and also shift whenever the shift light goes off.
