jkwool
Hi,
I have been working on ECU Editor with Petri And Jasa for awhile now and i have just finished working on some code that I though you guys would be interesting to find out about.
The new functionality just released allows you to hook up a wideband 02 sensor to your ecu and log the wideband Air Fuel Ratio data along side your engine data. You are also able to use the stock narrowband o2 sensor to log the Air Fuel Ratio of your engine along side other relevant engine data including Rpm, Gear, IAP (inlet air pressure), Ignition Advance, Coolant Temp etc etc.
I have also provided a Data Log viewer which allows you to load your log files and view the results in a grid with the same dimensions as your ecu fuel maps (both TPS-RPM and IAP-RPM). For those guys running turbos with ECU Editor controlling the boost fuel there is also a display that shows AFR at various PSI boost - RPM measurement points.
This functionality should allow you to check how you bike is running and make changes to your fuel maps to improve the tune of your bike.
The next part of this development will be to provide an auto tune ability which will take your logged data and suggest what changes should be made to your fuel maps to get to the target AFR values and improve the tune of your bike.
If you are interested in tuning your bike with the above functionality the following links will be a good starting point.
Ecu Flashing Harness ECU Flashing
Free ECU Editor Software : index
ECU Hacking Forum Post:
Autotune and Data logging for ECU Editor - ECU hacking
Cheers
-Justin.
Cheers
-Justin.
