MisterGDBusa
oil is $4 a quart at Wally World... changing the filter at 600 miles is a waste. imho
That's why I think they didn't even open the plastics.
Sounds a little steep. Think I paid $150. I have 2 shops nearby. 1 is 8 miles away and the other is 24 miles away. I go to the one 24 miles way because they charge a lot less and I trust the guys. Find a good shop that you like and that wont bend you over.
I think that the maintenance items that I do myself are probably typical of what a lot of members here do. These are the minimum that you should be able to do yourself for the satisfaction and the fact that you will do a better job than the dealer. Oil and filter change. Clean and adjust chain. Change and bleed coolant. Change and bleed brake and clutch fluid. Change spark plugs and air filter. Remove and replace wheels for tire change. "Check and tighten bolts". This year I'm adding break and replace the chain and replace front and rear sprockets to my list.
Are you using a by bass filter set up on the semi?
If your new bike made it in and out of the dealership without getting scratched, scraped, or otherwise compromised, you should consider yourself lucky and call it a lesson learned. I hate taking any personal vehicle in for service of any type. Half those guys are either animals, or incompetent, and no one is going to treat my vehicle the way I would. Learned this the hard way too many times. No mas..
Edit: ^Oh, and this isn't even factoring in the ass rapery that comes with the territory..
I paid $130 for the '06, they wanted $130 for the '08, I asked the owner about the warranty and was told it wouldn't be an issue. From memory my 600 mile maintenance cost me $26.
Then they certainly didn't do a proper by the book 1st service as they should have gone in and checked head, engine & frame bolts at random for tightness.That's why I think they didn't even open the plastics.
So the bike was for the first service at dealer and they made my wallet 230$ lighter.
They said they will do oil and filter change.4qt and 1oil filter.oil and filter change.4qt and 1oil filter.
Adjust chain.
Check and re-tight exhaust clamps and bolts.
Check chassis/frame bolts.
Check steering/tripple tree bolts.
Wheels
Brakes.
They said if i dont bring it to first service, i might loose the warranty.
When my semi truck goes to oil change and service it costs 265$.
9 gallons oil.
3 big ass oil filters.
2 big fuel filters.
1pack of grease.
Adjust 6 brakes
Check transmission and 2 differential for oil.
Check lights and coolant level.
I suppose it would be hard to tell unless you changed the filter yourself and sent it to a lab to be analyzed.
But even that might not prove anything...
A little trick is to deliberately put a blob of dirty grease inside the head of one of the allen screws they must remove to get a job done and to scrape the oil filter before handing the bike over....that way you will know straight away if its been done.
I know of numerous places that have just wiped the outside of an oil filter and claimed they changed it...same with air filters and spark plugs if they know the owner never touches the bike or wouldn't know any better.
Servicing is a dirty trade and plenty of so called mechanics / dealers will happily wipe you eye to save money and charge extra.
I have highlighted in red what they actually did.
My 600 mile service with oil change was $133.00. And that was a month ago.
Whatever you do don't wreck it. My off cost $4500.00 and it was all plastics and exhaust.
But you are not sure if you did it or the dealer?Exactly. Fellows, it is really extremely rare, i would say impossible to keep your bike dent and scratch free, It will happen something in or out the dealership. I have spent hours and hours being sad about a dent, scratch etc that I had no idea how it happened. what I have realized, is that it is better not to look and check it out each time you ride, because you will get insame. It happened to me twice the last 3 months
Yeah $230 seems a bit high over where you are but dont worry about it to much live and learn![]()
