- and if you use a more powerfull laser you can burn the hole at the same time...Easisted and most pain free way i learned Iceman taught
Tools
Laser pointer, Tape, Marker, small step ladder,, rear stand and your hole saw
Put bike on rear stand
1.Take your fairings off
2. now take a small step lader and position it about 3-5 feet away from bike
3 Take lazer pointer and tape the light so it stays steady on
4. slightly tape lazer pointer onto step ladder
5. Alighn the lazer pointer with the bold that will hold the slider and secure pointer to ladder
6. Replace fairing back on bike
7. Take tape and tape over the area that the hole will be drilled (make sure not to bump the ladder with the pointer on it or this will batch everything hence why the 3 to 5 foot range
8. Mark pointer mark on fairing with your marker
9. remove fairing
10. drill hole slowly so not to mess up fairing
11. remove tape work your way from outside to the center of whole to make sure you don't remove clear or other paint.
12. sand or add black ring materal to whole * can't think of name of it*
And now repeat for the other side
Well i hope that helps
Hey! If your laser is Really powerful you could burn both sides out at the same time! Oops...There's other stuff in the middle, isn't there.- and if you use a more powerfull laser you can burn the hole at the same time...Easisted and most pain free way i learned Iceman taught
Tools
9. remove fairing
