NDVBUSA
Hello all, my question is, has anyone had their front sprocket cover crack? I replaced my clutch steels, and fibers today and decided to change the clutch fluid. When I was bleeding the clutch master cylinder I heard a loud crack and found that I had cracked my cover just from pulling down the clutch lever.
Sounds unusual to me? Has anyone had this problem?
As I looked further I noticed my clutch push rod was slightly bent. (could that alone have done it?)
I see that schnitz sells a clutch slave support. Will that eliminate this from happening?
