Anthony Frew
Good morning from South Africa.Recently I had my 2022 busa in for a running issue, it ran rough when cold , could smell fuel like it was flooding, when warm it ran rough ( sluggish throttle response) at low and mid range acceleration. After doing the 12k service where plugs were replaced with new ones, the problem continued, after a week it was diagnosed with a fuel sensor fault causing more fuel to be pumped into the injectors than required. It turned out that the sensor was faulty and there was problems with the fuel mapping. All covered under warranty. Point of not from Suzuki nz is that the gen3 runs richer than the previous models, running a high octane fuel especially if ethanol is added may cause running issues, so check with your respective shop/ mechanic and always ask your gas station when and how often they do a " water check " on their bowsers as required by laws applicable to your country, as its possible that water may get in to the tanks.cheers team ride hard
I have a 2023 Gen 3 with over 36000kms run so far. I had exactly the same problem that Mike describes above. No ECM fault codes were recorded so the dealer could not diagnose the issue formally.
The problem was put down to sticky fuel injectors
The solution was:
1] Change to a different fuel supplier- in this case I went from Engen [our local Mobil brand] to Shell. Our fuel is 95 octane unleaded.
2] Used 3 cans of Motul Boost and Clean fuel additive initially and now use 2 cans/month .
3] Always cover the bike with a blanket and cover overnight in the garage [use the bike every day to work]
That was over 2 months ago without the problem being repeated, so I would say its solved.
PS never had this problem with my previous Busa's or ZX14R's.
