~~ galespeeds mounted on front ~~
(GPW @ Nov. 07 2006,07:50)
(runeight @ Nov. 07 2006,06
) Greg,
Check your email. Never thought to look at the instructions but it gives a part number for the rear sprocket.
17618-45 (last being teeth of course)
runeight...
so you want a 45 tooth?
No. This was just an example noted in the instructions. Calls for a 40 tooth rear.
I just wanted to see if your rear sprocket has the same part number. First five (5) digits.
runeight...
(runeight @ Nov. 07 2006,06:52)
) Greg,
runeight...
runeight...
I have a 41 stock for the 14 and a 16 front -1. So you want stock for the Busa which is 40 gotcha..
) Greg,
runeight...
40/41..doesn't matter. Just checking on the one you said you had in an earlier post.
Should I call you?
runeight...
(runeight @ Nov. 07 2006,06:57)
) Greg,
runeight...
Should I call you?
runeight...
at Starbucks right now........give me an hour.
