Dumped mine into a 5 gal bucket. Then used a suction hose. For the final bit I taped a big handful of blue paper shop towels to a long screwdriver and sopped it up. Had a small amount of sediment that I got with a shop vac.The tank inspector drowned...WTF??
Tank looks great except for the trapped tourist and those pellets...not sure what they are from.
Any way to empty the rest of the tank (without a mess) besides sucking a hose? I rode it beyond the warning light, but there is still about 1/2 gallon left.
Which hole did you dump it out of? top spout area? Just don't want to make a mess...Dumped mine into a 5 gal bucket. Then used a suction hose. For the final bit I taped a big handful of blue paper shop towels to a long screwdriver and sopped it up. Had a small amount of sediment that I got with a shop vac.
Bottom then top. Whichever will workWhich hole did you dump it out of? top spout area? Just don't want to make a mess...
I sprayed it out, but it's another one of those "since I'm in here" ideas...Because you are there is the perfect reason. Could you not clean your prescreen?
Any idea where this thread isThe tank has no rust that I can see. That junk was all dirt and varnish. I am thinking about using my power washer to break up the rest of the dirt inside but I don’t want to make rust. Any suggestions for tank cleaning?
The hole is a 3/16. I used @chrisjp write up for the drill size
@Kiwi Rider damn brother! Johnny on the spot! In Houston as well. You rock buddy
I ordered one of the new ones with all that poop out of it already. I’m searching my neighborhood for the Amazon guy.![]()
Fuel filter mod | Maintenance and Do-It-Yourself
a quick break down. i will do pics and description of two very different methods to this modification. one is easy in my opinion and i wish i had chose that route. the other is more difficult. the first method is the easiest and that is simply drilling a hole in the filter assembly to bypass the...www.hayabusa.org
To save the paint, I picked up a 20$ oil vacuum pump from harbor freight and just threw a hose and zip tied it to the end. put the Tank on a chair or tall box, pull the gas up the tube until you're a few inches from the vac pump and pull it off below the tank height so the pressure differential dumps it into a bucket.The tank inspector drowned...WTF??
