now for the left side (helps to have smaller hands here. i pulled the fuse's off their tabs so i can move them out of the way for more room. i also released the zip tie so wires moved more freely (press down on tab on back and pull end out)
Idk if I'm reading it wrong but shouldn't it be high beam on the bottom and low beam on the top with the rubber that needs to be trimmed?now for the most difficult of the install. the high beam. remove the connection by just pulling back. no tabs. and remove the rubber boot (shown above) by just pulling the rubber tabs. below you will see the bulb still in its wire clip.
yes... sorry you are right but i am after the time in which to edit it and correct that for clarificationIdk if I'm reading it wrong but shouldn't it be high beam on the bottom and low beam on the top with the rubber that needs to be trimmed?
Gen 1 ?????Sweet Write up Chris,,,
The kits are 100% plug and play, OEM connectors, And Bright
Ta DA
