banditzx10
only if you buy a import . Uk spec has mphyeah i looked it up both are used over there.
IF YOU BUY A IMPORT ITS STAMPED ON THE BIKE DOCUMENTS . AND THERE NOT WORTH ALOT OF MONEY .
MPH
fast thats for sureok but a dyno sheet won't prove everyone wrong. Video would show everyone what gear/speed/rpm that your running at 160mph. Horsepower has nothing to do with that, it just determines how fast you get there
your better going up three at the rear and downd 1 at the front .
i am just off the phone to the last owner this will clear everything up the bikes ecu has been set up.
they added timing to the lower gears (1-4) in what is often called a "tre" mod. This gives you more aggressive timing on the bottom and better throttle response overall. they remove the top speed limiter, all gear limiters, and raise the rev limit approximately 500 rpm. This would totally "de-restrict" the bike. this is one job am glad has been done . he said you can now go ahead and get it put on to dino .![]()
yes a new guy to a new bike . that you would think would have been made welcome . all i asked was about the busa in third gear never had one but when i kept on reading 160 in third at 12000 rpm was this normal or would the clocks be way out . not to be ripped to shreads .
well if thats the case the bikes not stock simple as that . i dont know what the man has done before me but am telling you 12000 rpm and no gear light has ever came on with me
