heli bars
ambulldog
just ordered a set. i commute 80 miles each way to and from work. developing a slight hot spot in my lower back and hoping these will alleviate that. it must be a longer reach to the bars than it actually feels like cause when im riding i dont notice any discomfort. next thing is corbin front and back as the wife saw the rear and backrest and gave the nod. that mod goes in her column
The corbin on the plus side will also change your body position over stock. So, since you'll have more BUTT support
, that might stop the hot spot which is probably caused by the flat seat and you moving (whether or not you notice it) on it. The Corbin will move you to the rear a little over the stock (unless your already BUTTING (Pun Intended
) the Hump. Which inturn will move your foot position forward a little. Again, a more comfortable position depending on your leg and arm lenghts. Plus with the Heli-bars you'll be sitting up more. Hope it works out for you
