So, watt you are saying is that you could not follow FI, therefore you state the 5th gear fallacy. This is basic book theory, not jibberish.
You contradicted what the book says, where you said all the basic abstract given [3-variables] explained in the trouble-tree are incorrect. Therefore, you dispute what sets off a code by 3 examples. Your 'jibberish' says otherwise. This is the debate, not arguing about a theory, but understanding the concept. It's like arguing the OTTO-cycle. How can you argue the 4-strokes is what I am asking.
The argument would be your denial of compression or the second stroke as in the beginning step is the intake, then compression. YOu being in denial of compression is to argue with a fool. That is the difference. I bring book (6)Locked. You bring a 5th gear variable from the air is tell the world where did you find 5th gear as the default signal you attempt to redesign the GPS internals to read 5th gear, when the tre defaults it to the 6-locked.
You logic says set the GPS and you get 5th. The jibberish in the FSM says the default goes 6 no matter what resistor you throw at it, she reads (6)Locked. That is how I threw resistor after resistor at the same wire. It still came up locked in the dash = 6 as per what the book says it will step to.
How can I bring up what you say, does not walk the laws of Ohm. You are even disputing the man Ohman are you. Lets take it one step at a time. You said, Smitha, you said that there is no code possible, we remove a wire from the coupler/connector = Means the same thing.
Someone is contradicting the other. I just want to get to the bottom of this and if the book points out the obvious, why cannot you explain that if you remove a wire from the connector it codes as per abstract in the pages I pointed out. Or the coupler is removed, it codes, or the sensor grounds itself, is this not the 3 fundamental basic variables to look for? We ignore your wire out she does not code?
Do we want to battle GPS signals we disconnect the couplers we code videos? We ground a wire, we code = Tre. Or, we smash the sensor, see if we can code the same thing. Did I give you enough jibberish to dispute your claim about the dash signal can be had 3 ways? Am I going nuts, we need to tell Suzuki to rewrite their book is call them, say they are wrong?
Smitha, I am walking a code set. What exactly are you saying as you talk it? I told you, I will use your words against you as to the walk of the Otto cycle is as exacting as FI... As in STEPS to the code set. Get it?
If you're gonna run withe big boys, you better have the right gear on, let alone be in the right gear, I need a dash to ride the rail.
Take a shot at it, Smitha. It's not like it's rocket science, but yeah, it is. Tell one switch to do a task via wire travel is switch from analog to digital is that switching. So, switch is it?
