If you read back to the beginning, the guy was using the wrong ohm resistor in his home made TRE.
Thanks, Whipped. I am going to add my little
here about a different resistor being used.
We are missing the diagnostics to the tre. We do not need a certain resistor. We can use any resistor. All a resistor does basically is act as a heat sink. That heat means the harness wire is not the resistor that burns all the way up the harness is that heat travel.
Now, if I uncouple = 6-Lock. If I remove a wire from the coupler = 6-Lock. And the last fundamental variable is if she grounds with any single reading heat sink, she codes the 6-Locked in the dash. You did not need to spend the cash on the dash.
That is basic book theory.
So, to move to a step more complicated, we have a single resistor sending 7 signals, (1-N-2-3-4-5-6) not 7 individual resistors tied in series. You can stop the bike in 3rd gear and start the bike. You did not see any code because the ECU recognizes the resistance, i.e., the analog (multi-signals).
When the bike shifts in the next gear, there is the next resistance read. Once you shift with the tre, that one resistor signal (single-signal), or the digital signal as opposed to the analog signal is read instead. Does not that sound like a short/unconnected/wire out of connector?
That on individual signal is a code setter. The seconds go by without the change in gear to that balanced resistance, then watt happens is that [read] bleeds through that one ohm read to ground [upsets the balance] and then through the wire it heads to the ECU to compute.
All of this this arguing back and forth about who knows more about FI theory and how its applied to the Hayabusa is off the original topic. Yes give it a rest.
"argument - a course of reasoning aimed at demonstrating a truth or falsehood"
"debated - disputed, under discussion, not settled"
All this back and forth about tre/ECU/Fundamental basics and how it applies is all about the Hayabusa and has yet to sway from the thread.
"Home made tre" say I have been chasing that tre 3 different ways. The 4th dimension is to comprehend what is FI theory to chase that problem.
That ford 02 hose manure cat spray wire rig is as simple as the tre and owns the same principals. So, the stangang with their car tre is fun due men till I'm blue in the face is discuss the tre thing a ding.
No one is pointing a gun to your head you need to click on this thread and tell others to stop discussing the debate and/or argument? I do not see it harming you, I have a mouse that does not click on tre threads kind of finger.
Besides, this is a car wreck in slow motion someone said.
