busakiller
Hey guys it has been my dream for a long time to hit 200 in the standing mile. This year iam going to focus on hitting my 200 mph goal. I have done a good amount of reading and research. Iam taking our shop drag bike and setting it up for lsr this winter. I will have some questions along the way and would like any good or bad feedback.
03 busa
3/4 upper fairing no lights
Mirror block offs
Sidewinder
Large air box mod
Pc5
Quick shifter
1397cc motor runs on c12 Made 205 ish at the tire when first built.
Flat 1 inch oil pan
Cut fork
Drag rear shock
01 sub frame
Bike weighed 460 with 1 gallon of Gas and a 12 stretch chromly swingarm
Parts I have ordered so far
18 front sprocket
Lower belly pan that connects to the 3/4 upper fairing
Also waiting to hear back from tiger racing about a lsr front fender.
Questions
What tires do I run?
What size tire?
Rear sprocket?
Swb or use my 4 inch swingarm extensions?
I know traction is limited at the events but don't want to fight the bike from the wheelies. The bike will have about 1 inch of ground clearance.
I do plan on getting my ecu flashed, 42 lbs injectors and fuel system upgraded, and get the bike returned on c16 and a small shot of spray, and swap out the heavy lead batterys for some light weight batterys, I will also getting a tank shell.
Once I get the belly pan mounted iam going to get my forks set up for the ride height I want. Since right now I have over 2 inches cut out of them right now.
I will post pictures up when I get back out in the garage.
03 busa
Mirror block offs
Sidewinder
Large air box mod
Pc5
Quick shifter
Flat 1 inch oil pan
Cut fork
Drag rear shock
01 sub frame
18 front sprocket
Questions
What size tire?
Rear sprocket?
