dirty dave
Ok guys just looking for some feed back on the issue not sure if i want to do it or which way to do it
Easy enough and the fan still works automatically? nice
the cons are, you must be sitting in traffic, try taking a back road
Run a ground wire from your battery to a switch on your dash and from the switch run the ground wire and splice it into your radiator fan's ground wire. The ground is what triggers the fans to come on.
So Russell.... first thing... OHHH RAHHHH 1980 - 1988 Semper Fi...
Secondly... I am thinking about doing this to my Gen I. The owner before me wired it to what looks like behind the thermo. All I know is there is two wires taped up. When I toch them together the fan comes on. So I assume he had a switch. I am going to add the switch and connect the wires. My ? is does it REALLY work. So if I roll up to a traffic jam and I instantly hit the switch, will it make a difference if I have to sit in traffic a long time? By turning on the fan before it reaches the temp that it would automatically kick on? Seems like it would but I would like some input...
Thanks!
All you have to do is run two wires directly to the fan relay on the left side of the radiator (Gen 1) . . . run them up to a switch, because that is all the fan relay is. The switch will overide the fan relay, but the system will still operate normally if you do not use the switch . . .
Is it by the fuses?
Cool.... Thanks Russell... I can't wait to hook this up and test it out!
ok I tapped the ground wire ran it to the swich then from the switch i grounded to the frame, so i assume doing it this way the factory switch will still work the only draw back i see is if somebody want to screw with you they can flip the fan switch and kill the battery
It's in the top left corner of the rad.
I did the same.
But I believe it's just a coolant temp switch, not a relay. The switch closes (when the coolant temp in the radiator is high enough) triggering the fan relay to energize, thus turning on the fan.
iPhone. Tapatalk. Out.
