mps fast FI mixture control
dragonbusa
Any one have any experience with these? I"m manly interested in the instint rich mod for dry shot set up. any good or bad experience?
It works good. You have to tune the nitrous to whatever "instant rich" turns out to be on your bike, so set it up on a dyno. It usually ends up being 50-60 rear wheel at a safe A/F, just don't get too greedy with the nitrous!:laugh:
so a fifty shot should be good?
I've used one for about 4months or so. Worked good, no problems. Give BoostBySmith's ECU flashing kit for nitrous systems some research. You won't be sorry. No more bulky boxes or switches, just one 4pin connector.
Give it a looksy here:
There's a Nitrous tutorial in there that'll some it all up.
Good luck.
Good luck.
Thanks, My go to man, (chuck) at topelo performance talked me out of it. I"m going with a mutifunction hub and a custom nos map.
I am in the process of getting some motor work done. I want to run Nitros any tipss. I am getting the heads a port and polish job and the bottom end done.
Good luck.
Still working :bowdown: :lol::beerchug:
but will be changed to ECU flash because of the charger
If your going that far, go with stainless steel valves and forged pistons, then you can spray the hell out of it!
