My 05 Has Problems
MoosesBusa
Former BusaHolic
Bought the bike 2.5 weeks ago. Have already had to replace the head gaskets ( leaking oil onto exhaust pipes ) heli coil the fairing bolt into the frame and I just got on the scoot to take a quick ride and the ignition shorted out. Seems the Positive battery cable end grounded against the frame. The battery is in the freezer cooling down now. It was almost too hot to carry. Are these problems common for a bike with 400 miles on it?
Secondly...where can I get a service manual for this? The dealership doesn't seem to know.
nice try but you are full of it.
no oil goes through the head so you cannot have a headgasket leak of oil
Welcome to the board.
Can you say Lemon Law. If your already having this many problems I would look in to getting a different one. Either that make them give you a extended warrenty.
If your Being upfront, then you have unique and special problems. I think maybe we cshould change your screen name to "LightningROD"... Sound skinda whacked, and sounds more like you bought a Kawasaki, not a Suzuki...
My fault just looked at the title again. '05, huh, yeah you might think about dealing with someone else next time.
It would be nice if cap could find out which site this troll is from and everyone goes over there and swamps them with non-sense! Why Don't you go stick your head in the freezer along with your battery, you will be in good company since they both seem the be depleted!
What the hell was the use of this post?
If this is a fabrication, I'll repeat again, what the hell was the use?
It didn't zing anybody, make fun of anything, or really do anything at all!
I am absolutely stumped that someone would join a site just to post something like that.
It made no sense, wasted 10 minutes of his life, 5 minutes of my life, and made me lose all respect for this person and whoever brought them into this world!
We really need an age and an IQ limit to sign up for this forum.
Both numbers must be double digits or you may not join!
Wow. Glad to see there are so many knowledgeable people out there. Yes it is an 05. Yes I purchased it on 11/16/04 VIN # JS1 71A6521 848. It is blue and Silver. Apparently there IS oil going through the heads because they replaced cylinder head gaskets part #'s 11173-24f00,11178-33e00. If you want the fairing screw # it is 09139-06087. The battery was grounding out on the frame because the idiot that assembled the bike put the wires to the side rather than the top. As for signing up to this board to spoof someone, I did not. I have a real problem and was looking for help. You guys can kiss my happy white...
<!--EDIT|Ninja Eater
Reason for Edit: None given...|1102201789 -->
So why isn't the dealer taking care of these issues under warrenty, and why would you have to ask if this is common with a new bike when it's obliviously they are not?
If you did have those sorts of problems then I would have tried swapping bikes...If your legit you will get help here...
I just got my new replacement for my 02 Busa that got rearended ... An 04 Busa ! And I tell you what , If I had that many problems with my new bike , i'd tell the dealer to give me another new one or i'd see a lawyer ! Someone had to be smoking crack when they put that one together !
He was fooling ya'll...he meant to say it was a Hardly Ableson and not a busa......
and hey bro you can kiss my happy brown......
Wow. Glad to see there are so many knowledgeable people out there. Yes it is an 05. Yes I purchased it on 11/16/04 VIN # JS1GW71A652100848. It is blue and Silver. Apparently there IS oil going through the heads because they replaced cylinder head gaskets part #'s 11173-24f00,11178-33e00. If you want the fairing screw # it is 09139-06087. The battery was grounding out on the frame because the idiot that assembled the bike put the wires to the side rather than the top. As for signing up to this board to spoof someone, I did not. I have a real problem and was looking for help. You guys can kiss my happy white...
look real close at the rad fan. you see the hose going from the case to the head???
there is your oil!!!
the oil oil that could even thing about leaking is on the cam tunnel but no pressure there and it would not be even close to the exhaust.
Tell you what you want help post the warranty ticket
Hmm..J.C. could it be the valve cover gasket ? Not every one is a Motorhead ---head gasket ,valve cover gasket- same not same - same. Lets hear him out---- If you are for real--a Welcome to board..PaceM
he should have had 1-11173 and 4-11178
those are for the Valve cover and the 4 sparkplug O-rings and yes not a head gasket but a Valve cover gasket.
That is why I wanted to see the warranty repair order, The point I am making is his white happy ...... can't get his facts straight
