Tian
Good day,
So from November i noticed a oil leak. Its not leaking always and 5 or 6 drops then it stops.
So when we fitted the new fairing we cleaned everything and had it idled to hot temperature, but nothing. About a week later it started again.
I fitted a new chain and sprockets about a month or so ago, also had the complete engin clean and went for a hard ride naked, left it for a couple of hours, idled again but no leak. Rode for another 2 or 3 days and no leak.
About 2 or 3 days later after i fitted the fairings again, i found the first couple of oil spots again. When i remove the fairings then i cant see where it comes from cause my sump is wet, the left side engin covers is also wet so i really cant tell where it is originating from.
The oil drops is below the sump plug area and sometimes more to the kickstand area.
What could cause this or what seal may cause only temporary leaking?
Had 2 different mechanics looked at it but not one can tell.
When i drive to work at morning, no leak, when drive during the day or home afterwork, then it is dropping a few drops of oil. When i go for rides late night usually also no leakage. So its also when the climate is quite warmer i could say.
I am currently running Fuchs Silkolene Pro 4 10W40 oil.... That is what was suggested to me. How do you find that oil? For hot dry climate areas.
