Why are you going about this the hard way ?
Get leak dye and a black light .
Then you'll see everywhere there is a leak *
Why are you going about this the hard way? Get leak dye and a blacklight. Then you'll see everywhere there's a leak
That leak dye with a radiator picture on the bottle ?
( Forgot the name - laugh out loud )
Which seals, have you ordered? Do you know exactly where the leak is coming from?
To give you an idea on how Suzuki is here.....
First time i went there and asked them to show me a variety of tyres they stock for my Gen2 Hayabusa- they went to the store and brought me a Motorcross nobby tyre...
Again after that when i phoned for sprockets and chain-again for the Gen2 Hayabusa they asked me what it is? I replied what do you mean and they asked me is it a Kawazaki/Triumph/Suzuki/Aprilia/Honda/Yamaha....
So about an hour ago i phoned.... They would have called me back in 10 minutes time, so i will call again at 14:00 and if they cant answer me i will be paying there shop a visit and let them understand AGAIN how dumb and useless they are...... :-)
It's their loss Tian, better off not doing business with morons like that lot.I ended up getting the seals from a local shop called Buddies Bikes.... Until today i have not heard a word from Suzuki but the sales person there and me ended up having words for each other about there bad service and i lost my temper a bit and yeah now my doors are closed there. I may not be their customer anymore.
Just use the internet to order and supply parts for your pride and joy my friend. Way better.
To add something to your ‘push rod’ seal situation.
I forced my one out of my engine, without splitting the crankshafts, (I didn’t check the book, my mistake) so, I ended up with a BIG problem the new pushrod seal, is included, in the new clutch slave cylinder repair kit, so I presumed, changing the pushrod seal, would be easy, I couldn’t believe that suzuk, would use such a terrible design on their engine, for what is basically a consumable item.
I managed to trim the raised lip of the new seal down on a bench grinder, clean up the recessed hole (once I’d removed the old seal) with brake cleaner, squeeze a load of oil resistant rtv in, place the ‘modified’ seal in the hole and install a nice fitting cir clip over the seal, inside the groove, it has not leaked since doing this.
If you do decide to machine a thicker rod, I can tell you, that once the seal is out the hole that you have, is not much bigger, than the pushrod, so, it would be wise to investigate how much bigger, than the original size, you can go.
u might really seriously consider leaving the bike dripping a little and during the off season doing the work... shop around and order everything u might want to do and plan it out... might wanna try to do the engine removal yourself.. maybe a bigbore kit/headwork![]()
