Click on the "attach files" and you can post it...I was sent a vid of the previous owner rolling it over, is there like a certain place I can post it at on here?
It almost sounds like an ECU issue...This is all that happens when I turn the key, I can roll it over, it has spark, and the fan stays on constantly
Yes, when in doubt, get a battery you can trust....these things like their battery power....The other engine I have actually the chain popped off an broke the side casing and I was told it might have a crack in the block because it leaked oil out but I haven’t really messed with it, and i don’t know what that was in my hand in the first picture. I had the battery on charge but I might go get another battery
he said the trans went bad in it cause you can wiggle where the shifter went a lot but idk what that box is either it was kinda just put up under the other wiresYes, when in doubt, get a battery you can trust....these things like their battery power....
Make sure the terminals are very clean......take a little steel wool to them.
So the drive chain came off....and wrecked the case....no other damage though?
I'm not sure what that box is in your hand, any writing on it?
I plan on it, I was rolling it over an the wire on the fuel pump starting smoking so ima take the gas tank off an mess with the fuel pump wiring an try to fix it. Also the bike rolls over very slowly, I bought this battery little bigger than the old battery a few weeks back an it’s still good so I put it on the bike an it just rolls over very slowly even with jumper cables on hooked up it doesn’t change a thing rolls over same speed but this motor in the bike hasn’t ran on this bike yet that’s why I want to check for codes on it to see what’s all wrong, the previous owner may have neglected the bike but I plan to fix it an make it beautiful againIt looks like he used speaker wire on the fuel pump...
That bike needs to be returned to OEM....that box might be a TRE...other silverbacks will have to chime in here...
You definitely have your hands full with this bike.....
It looks like it's been rode hard and put away wet on more than one occasion....
Hopefully you can sort it out and save it but it isn't going to be an inexpensive venture to do so...
So the motor in the bike hasn't been run....I plan on it, I was rolling it over an the wire on the fuel pump starting smoking so ima take the gas tank off an mess with the fuel pump wiring an try to fix it. Also the bike rolls over very slowly, I bought this battery little bigger than the old battery a few weeks back an it’s still good so I put it on the bike an it just rolls over very slowly even with jumper cables on hooked up it doesn’t change a thing rolls over same speed but this motor in the bike hasn’t ran on this bike yet that’s why I want to check for codes on it to see what’s all wrong, the previous owner may have neglected the bike but I plan to fix it an make it beautiful again
The battery is new and even with booster cables on the bike turns over very slowly?
Sounds like something is off...how does the oil look?
How do the spark plugs look?
I'd definitely get the wiring sorted out before the thing catches fire....with all the bastardization of that wiring, I suspect something has shorted and maybe fried a few sensors/switches....I suspect there may be issues with one or more of those...
It looks like the bike has been over maybe more than once,
And that fuel pump doesn't look new.
Make sure you have a manual. this will help you quite a bit.
Yeah I do need a manual but I haven’t checked the spark plugs yet an all I’ve checked was to see if there was oil in the motor I haven’t messed with it to much cause of work an I know the pump doesn’t look new that’s why I wanted to get another, but the bike does have compression some good compression actuallySo the motor in the bike hasn't been run....
At least you saved it from a bike wrecking yard...Yeah I do need a manual but I haven’t checked the spark plugs yet an all I’ve checked was to see if there was oil in the motor I haven’t messed with it to much cause of work an I know the pump doesn’t look new that’s why I wanted to get another, but the bike does have compression some good compression actually
most likely and yeah I’m very glad I have the chance to save this bike, I plan on making it the color it came from factory. But as of right now I’m taking all the wires off to the fuel pump to check for shorts an to do it the right way aroundAt least you saved it from a bike wrecking yard...
But you will be pulling your hair out before long trying to chase the gremlins...
I highly appreciate all of your help, I took the gas tank off an got the fuel pump out an it was some filthy rust colored gas in it I got some pics of how he had the pump ranYou need a multimeter set on volts, check the voltage at the battery, should be at least 12.5v.
Then check the voltage drop while "rolling" (cranking) the engine with the starter motor.
If the voltage drops below 10v, you either have a faulty or flat battery, a bad connection or bad cable from the battery to the starter, or a bad ground connection between battery and the chassis/engine, OR a faulty (bad) starter motor.
This (above) is the testing regime for the starting system.
Connections and condition of cables from battery to starter motor and chassis/engine ground are absolutely critical, MUST be clean and secure/tight along with, of course, the battery condition., MUST be fully charged!
The cooling fan running all the time may be as simple as a faulty thermo-switch in the radiator, but may also be caused by a ECM fault.
Test the thermo-switch first to eliminate that as the fault... or not.
Remove the spark plugs, bin them, and get a new set of plugs.
If the plugs have a fat blue spark while cranking the engine, all good.
The wiring situation you have there is like a 5 year old child has been playing with it.
Rewire it with the correct gauge wire and follow diagrams and wiring diagram from the SERVICE MANUAL.
Get a NEW fuel pump preferably, or a GOOD tested used item.
You will need to test fuel pressure with ignition on and cranking... must be 3 bar (42psi)
You will also need to test for pulse at injector connectors using a 'noid' lamp. (google it)
If there is injector wire pulse but still not firing, remove the injectors, leave the connectors on them, and crank the engine, is there fuel spraying from them? Yes, GOOD, no, BAD. faulty or clogged injectors.
Once you have established these critical tests and followed this procedure, let us all know the results.
All the best with this mate, you certainly have a dream, and a goal, and your hands full lol.
YIKES!I highly appreciate all of your help, I took the gas tank off an got the fuel pump out an it was some filthy rust colored gas in it I got some pics of how he had the pump ran
