I’ve been doing some thinking, wouldn’t I have to change the flywheel to the 06 motors flywheel? Cause I didn’t get the ecu for the 07 motor, so couldn’t it be firing at the wrong time?
No, 2002-2007 Busas are the same.
An if you don’t think that would work, when I get the rear sprocket in couldn’t I just pull start it to atleast see if it runs?
Transmission problems tend to be 2nd gear slipping, and the trans needs 'undercut' by a machine shop to fix it.I just ordered a new fuel pump but couldn’t I take the transmission off the 06 motor and take the transmission off the 07 motor an put the 07 transmission on the 06 motor? If I can’t find out what it is that’s wrong with the 07 motor that is
Good advice right there...I think he is getting a bit ahead of himself here regarding the transmission . . the name of the game here is to get the motor running first, to assess the condition of the rings, pistons, valves etc.
It doesn’t crank hard or slow it cranks as it should but I can believe it jumped timingPossible bent valves, which would explain hard slow cranking, jumped timing.
I would download the manual from here.It doesn’t crank hard or slow it cranks as it should but I can believe it jumped timing
I would’ve did a compression test but I don’t have the stuff to do it and I’m on a budget right now so that’s why I haven’t bought the manual yet, but it did it when it was cranking I kinda think it was because I had a little bit of gas in a jar when I went to start it, I poured the gas in the throttle bodies but it wasn’t much gas so I believe it backfired through the intake cause to much fuel to the throttle bodies. That’s my thoughts but I wouldn’t doubt it if I’m wrongChanged the plugs....you had them out why wouldn't you have done a comp test?
Well I wouldn't have cause it's 15 degrees in my garage.
Backfired,,, when you crank or seem to kick right as you let go of the starter button?
I truly appreciate your dedication and willigness.most likely and yeah I’m very glad I have the chance to save this bike, I plan on making it the color it came from factory. But as of right now I’m taking all the wires off to the fuel pump to check for shorts an to do it the right way around
