Re torque all the bolts - use liquid wrench and try again...
When removing multiply bolts/nuts from a torqued surface, break each bolt free and then re- torque moving around the surface when all bolts have been broken loose then use a criss cross pattern and loosen them. When torquing bolts back up - move in a criss cross pattern snugging up the bollts a little at a time until all bolts reach full torque specs...
