hollywooduno
Hello busa community! I have been gone for a long while but recently picked up a 2012 with ~30k miles on it. Prior I had a '99 and '02 but life got in the way for a while and I took a break from riding. Now on to the bad news....
The bike I picked up clearly has been ridden hard and put away without any maintenance being performed. Before my maiden voyage I replaced tires, brakes, brake fluid, oil & filter, and fork seals. Also did a lot of clean up. Then on my first day out, I made it about 2 miles down the freeway before the bike fell out of 6th gear (under normal load) and into a false neutral between 5th & 6th with a lot of horrible noises coming from the trans. I went down into 5th and everything seemed ok, but when I went back into 6th, it again fell into the false neutral with horrible grinding noises. The bike will not shift down into 4th, 3rd etc, and will make horrible noises in 6th, so 5th is all shes got.
I contacted the prior owner to ask what was going on and he is claiming there was never any shifting issues. I took it to the local dealer and they have concluded (without splitting the cases) that it needs a transmission rebuild. They are quoting $1700 in labor plus parts.
My questions are:
1. Did I buy a lemon, or is it possible this is the first time this happened?
2. Would you just do the transmission rebuild or would you lean towards an entire engine rebuild to ensure there aren't any gear pieces floating around in oil journals which may cause issues later?
3. Should I go for the ultimate "while you're in there" and look for a big block kit for it? If yes, who should I go to for this?
4. Who is the recommended shop to perform this sort of work in the L.A/ San Diego Socal Area?
Thanks in advance!
My questions are:
Thanks in advance!
