Yes , you can see the hole in the head casting under the exhaust port in your photo- Designed to drain water that may get into the sparkplug wells. Weeps oil out of those same holes when one or more of the sparkplug tower seals are leaking. Each of the four exhaust ports has one. I don't think you have a well seal leaking. Happened when filling the cylinders with oil.
so the oil that was sitting on top of each piston was ejected out through those holes when i spun the back wheel causing it to rise high enough to go past that hole?lease:
