Much appreciated Mr Brown, you are most welcome!And sometimes, they'll even be correct....
I'm kidding. Kiwi, your help and willingness to give it are a Godsend.
Wait? I can do that??? I actually didn’t think of that. I guess that would still allow me to keep the calipers in place too. I may give that a go after I make sure the rear brake is putting out decent oomph. Still means I have to face my fear of pulling the front wheel off the bike lol.Take the rotors off and test drive it. Will eliminate that as a problem.
If you do take the rotors off as suggested by MathewRussel, I would recommend putting a brake hose clamp up on the hose near the master cylinder, just to prevent an absent minded pull on the brake leverWait? I can do that??? I actually didn’t think of that. I guess that would still allow me to keep the calipers in place too. I may give that a go after I make sure the rear brake is putting out decent oomph. Still means I have to face my fear of pulling the front wheel off the bike lol.
Yes, you're dead right there mate, taking off rotors is way too much work, as you correctly said, there are easier ways to check the run-out on rotors and the preferred method is a dial indicator gaugeNo no no, come on. You’re not gonna remove the rotors to check to see if they’re warped are you? A micrometer will do that. I’m sure Kiwi isn’t recommending to check rotor warp that way but is just giving you the correct way to remove the wheel.
Will likely eliminate any other problems that bike has also.Take the rotors off and test drive it. Will eliminate that as a problem.
I do happen to have a dial indicator which we use for checking the pinion depth and backlash on rear ends in trucks when we rebuild them.Yes, you're dead right there mate, taking off rotors is way too much work, as you correctly said, there are easier ways to check the run-out on rotors and the preferred method is a dial indicator gauge
but most people don't have one, they are expensive, and most people don't have access to the use of one, or even know how to correctly use it to measure rotor run-out.
If the rotors do have excessive run out the brake lever will "pulse" when applying the brake, and you can actually see the run out if you look closely as the rotor spins moving past a close fixed object such as a caliper.
If the rim has 'rash'on it, I would be checking for run out in the rim itself.
The wheel alignment may be a bit out of true as well.
Do the handlebars look straight when riding straight ahead??
If not, the front end is twisted and needs looking at to ascertain what's causing it to be out of true.
I will give it go with that and see if I can determine any run out from the measurements.
Bike drives straight down the road and while riding at 30 ( that was the fastest I felt safe taking it to at this point....I don't need the bike getting wrecked again before I even finish).
It is is the oddest feeling and I don't even know how to effectively describe it. It almost feels like when you grab a fist full of front brake and the front tire is plowing looking to lowside.
If your front brake hose are oem rubber, clamp off one at a time, with the front wheel raised, and check braking efficiency left and right, you may have a caliper issue. . .I do happen to have a dial indicator which we use for checking the pinion depth and backlash on rear ends in trucks when we rebuild them.
Excellent advice! Good place to start too re handling problemsHave you checked the fork settings?
Are they both the same?
I have set up suspension for people and found each fork set far off from the other.
If one is stiff and one is soft, it will give the sensation of pushing to one side, and feel like it wants to lean over on the other side, as if the front end is fighting itself, which it is. As when the front end dives under braking, the stiffer set side is doing the majority of the work for both forks(and it will feel, brake and handle badly).
Count the turns or clicks and wind the compression and rebound all the way clockwise and count.
Back each out 3-4 turns, just as a reference point.
Also make sure the preload is even.
If they are the same, but are set very soft, the front end will also wander some.
Regardless, the suspension sag needs to be set correctly, front And rear, otherwise, it's not just handling that suffers, but braking and traction also.
