Scipione420
If your doing the inners make sure you use flex primer and and flex promoter. If you want smooth inners use the promoter first. After the promoter dries you can put a few coats of primer, let the primer dry and then sand it a little. Then put a few more coats let dry and sand. DO NOT pile the primer on b/c it wont work. If your going to do the inners you wanna do them right. Just make sure you use the flex primer and then you shouldnt have any problems.......
I think the smooth inners look so much better. Just take your time....
