Well, everywhere up to 100% throttle is great. On full throttle, the bike in the upper RPM's (8000-9000) acts like it hits the rev limiter. The throttle does not react until the revs return to idle. I watched the fuel pressure go where it is suppose to be at 100% throttle, back to idle pressure when this happens.
I have a GiPro w/TRE but never used the TRE. My tuner set it to the 5 setting and on the next run, the problem occured at 6000-7000 rpm's.
On the street, I tested the bike at full throttle in 3rd and fourth gear three to four times. Each time the bike didn't have any problems reaching 11,000rpm's. I still have the TRE on the 5 setting.
My tuner thinks its the throttle position sensor. Anybody have a clue what could cause this?
Thanks.
Thanks.
