Quart
Good day,
question for my Busa - model 1999/2000 (350kph 16bit cpu external fuel pump). Owning it from 2016 (33.200km) to now (96.000km)
Bike has steel pipes (dekat) from 2:1X:2, PC3 usb.
The bike runs fine but shows some problems on the erogation.
History below:
This is after I sync'd and setted the TPS
7) So we have a problem and I'm not sure where to bash my head.
Excluded spark plug pipes and injectors, would run at 2-3 cylinders but not die 100% suddently
Excluded burnt clutch, could act hectic but would not die.
Excluded battery issues, I can restart as much I want, engine starter has always the 100% power
Checked tank breathing outs, they both work.
Fuel Pump hoses seems fine.
The problem seems correlated to the fuel pump: sometimes but not always seems to stop working. Only when tank is half empty or less.
Still can run around by restarting the pump and re-pressurizing the fuel rail.
Some busa bros suggested to check the stator, could be that failing hard but this would lead to fuel problems at all tank fillings.
I'm in doubt between the fuel pump starting to die or the fuel pressure regulator that stopped working or what.
What could happen if i choked the fuel pressure regulator by blocking the fuel passage 100% with a sheet of metal inbetween?
Would I have the pump keeping max pressure on rail at all times?
Any suggestion?
Thanks and good riding =)
History below:
All started at 90.000kms last year or so.
- First thing comes from travelling with minimum gas (example in the traffic with <10% gas throttle and below 3500rpms): while keeping the gas at a fixed % you can feel the engine "draws back" every here and there also hicc-upping.
- Second comes when you are travelling with less than 50% fuel tank (averagely 2 gallons left or less). The bike initially under heavy acceleration and later even in low pace stalls, draws back like not enought fuel. If you close the Gas Throttle minimum looks fine, open it again and partially, bike dies. Restarting with from 0 (fuel pump relais triggering) solves it.
- Third, sometimes opening as from 2-3000 rpms shows an "empty" moment when engine goes blank (for like 1/8 of second) and then ramps up.
- Fourth, milleage was horrible (10/13km per liter even at low paces)
1) What have been done @Doc mech:
- Engine head redone at 91.000kms since valve oil seals were burnt and leaked oil. Compression at cold it's 10.5, the engine head gasket was still perfect but there was junk in the coolant circuits. Everything back anew.
- Changed fuel pump filter and cleaned it
- Piston rings
- Valve stuff and chain
- Sync'd TBs
2) Bike was fine but still was dying suddently.
- Opened it and found swapped fuel hoses, setted them in order, the hoses were collapsing under heat and fuel choking the pump.
3) Improved but not enought
- Cleaned the fuel press reg screen filter (Doc Mech didn't know and it was soaked)
4) Better and worked for a while (millage ok and less stuttering) but it ate spark plugs NGK CR9EIA-9 within 4000kms.
- Noticed there was alot of struggle on fixed gas like the engine was out of sync
- Plugs were white-greyish
5) Decided to check exhausts pipes since mufflers had dbkillers completely black (bad combustion?). Discovered that dbkillers were different (one shorter than other). Ran without them and stuttering etc was much less, not unsolved but that flashed out a problem: they made TBs work unevenly.
- Ordered 2 DBkillers with better output and long the very same
- Sync'd again the TBs, fourth cylinder was skyrocketting to the moon.
- Setted TPSensor: it was out again.
- Changed plugs to standard CR9E
- Cleared BMC air filter
- Checked the Fuel Press Reg
- Increased PC3 fuel to 6-8%
6) With this we come to yesterday. After the whole went to run with 2 gallons of fuel or so. Engine felt very steady, well ramping up.
- Still while accelerating with 6 liters (1 and 1/2 gallons) or so felt the engine starving fuel.
- Slowed down at 40mph or so, slightly accelerated, it died.
- Off/On again and no problems.
Any suggestion?
