Lol... Thanks Delbert, tabs down it is.. (that helps tremendously) Once I found out what they were, research within the .OrgVault says to replace.
Also the Engine mount lock nuts (the two that mount engine to frame thru transfer case) ; manual states once removed they are of no use. So... new nuts and exhaust gaskets should be delivered week ending.
Cylinder block cleaned and prep'd this weekend. Lower half of engine ready to take on the "new" head. (Pic's forth coming...lol)
Needing to pick up a shim kit. Just realized w/ a valve job performed; I'm needing to start anew.
Really not sure on how to start a shim process from anew head.
I'm guessing; put the tappets on without any shims. Put cam shafts in. Measure clearance to determine shims needed? Which means I'll be needing a shim kit..
(Can't wait to pull together the list of parts not accounted for on this "simple" gasket project...lol)
Preciate the Kudos' there dmallord!
Peace out.
Peace out.
