Aren't they made by Germany bro ?Spigler customer service on the kit imperfections , and misrepresentation of using stock mirrors is why I'm saying go with the other company . However I believe all are made in the UK. ABM top clamp / LSL bars
I believe you are correct Andrew . Sometimes we Americans just throw a generic country for across the big pond . I should of remembered though as much dealings that I had to do via e mail .Aren't they made by Germany bro ?
Hey Dai, was this a Beringer, Galespeed or something else? Sounds interesting.On the other hand,i have the Billet M/C on the LE and it bites even harder and more smooth over the 19. Pricing is $900 or so.
Brembo Billet M/CHey Dai, was this a Beringer, Galespeed or something else? Sounds interesting.
I see Berlin talking about how the bigger 19s are more aggressive / scary than the standard 16s. As I understand it the smaller the master cylinder piston the less pressure / more movement at the fingers and the more pressure at the callipers. So wouldn't we have to squeeze harder with 19s to get the same stopping power while the less leveraged system may provide better feel? Or have I got that backwards on the feel maybe and the lower pressure at the fingers offered by the 17s put the feedback into a more finger sensitive range. It looks like the people with the experience of swapping M/Cs in and out are saying sort of the opposite. Is it just that the 19s seem more grabby due to the initial rapid calliper movement maybe? I feel like I am missing something. If you were to do the Busa again would you maybe consider 17 CCs to dial in the initial bite of the 19s but the power / feel of the 17s?I run a RCS17 on the Busa , got a RCS19 for the ZX14R . I like the feel / feedback the RCS17 give , mated up to the black GP4RX , and the huge 330mm ductile iron rotors .
The Kawasaki will have the same calipers , but standard rotors for now , with the possibility of 330mm stainless rotors to follow .
Reading this thread I'm still uncertain. Which is best for feel and performance. RCS19, RCS19 Corsa Corta , Corsa Corta RR or the R1 Master CylinderRCS19 . Made my own bracket for nothing ,and bought a Brembo small clutch reservoir cup in smoke . The 19 does have a adjustment for pwr / feel too . Pivot of 18 mm or 20 mm . Here is a link to Brembo on the topics .
Master Cylinders
www.brembo.com
If you go R 1 do the latest year you can find .
No ten year old stuff unless you're going to rebuild it too.
