it looks like some kind of fuel/cleaner got on the line and discolored it...it also might have been splashed on there by the rear tire like Mr Bogus said
have you used any solvents or cleaners on the rim? your "fuzzygraphs" are pretty hard to see but it looks like it might be just about where the sidewall of the tire would sling stuff
anyway, you may want to call the maker and see if there is a warranty on this.. this could be the beginning of the end for the sleeve. (I doubt it has any thing to do with the integrity of the part at this point)
Looks like this is no burn mark but discoloration. Like line was pulled back a couple of inches and that clamp with black rubber insert where that marked part previously was. Could it be the case?
Vic,,it's turning to carbon,,,i'm no expert,,but im a Chef for 30 years and know heat,,lol. The line is only 4 mo old,,and since last pics,,more carbon on rt side now,,,Riding hard on Sat,,,will try and get better pic's.
could the line have a pinhole and be letting brake fluid out underneath the plastic covering under really hard braking? would brake fluid react with the plastic line cover? can't tell from the pics if the discoloration is only on the outside of the plastic
