I can tell you one stock front rotor is just over 3 1/2 lbs.
Depending on linear style caliper or radial caliper if I recall the radial is slightly heavier.
A radial caliper complete is about 2 1/2 lbs.
The rotor bolts are 7 oz.
So you are looking about 6 lbs. 7 oz.
HA I can, well...the only ...um...thing is ah I have to ...um...eat it first. ;<)Not to many people can deliver a homemade B day cake .]
I've not eaten all day and ran out of fuel on the return road in the pursuit of winning a drag race, so I understand the sentiment, but removing a front brake doesn't seem like a good idea to me.I might be missing something here. But if beating someone with years more experience in a drag race is what this is all about fwiw imho taking. Rotor off is a waste of time and may bite you in the butt when you are street riding
If you want to save weight go to the track with only a gallon of fuel in the tank. And bring some more in a container. Of course this presumed you trailer Fuel is ten pounds a Cdn gallon.
Millions of dollars !! , for tokicos that were inadequate in feel and somewhat lacking in power , in either 6 piston axial or 4 piston radial for 12 years and '13+ only invested the $ in half a fix , with the monobloc Brembo mated with that same master cylinder , holding it all back , right from day one !!If the bike's sole purpose is to drag race and nothing else, one front rotor might be OK, if the bike is going to serve a duel purpose, leave both rotors, it is a heavy bike with gobs of power and one rotor would suffer serious brake fade on the street in my opinion. Suzuki spent millions of dollars and time to sort out the brakes on their bikes for a reason.
My $0.02
I would wager the R&D would be in the millions over time would it not? I always thought the R&D was the money.Millions of dollars !! , for tokicos that were inadequate in feel and somewhat lacking in power , in either 6 piston axial or 4 piston radial for 12 years and '13+ only invested the $ in half a fix , with the monobloc Brembo mated with that same master cylinder , holding it all back , right from day one !!
Brakes from the parts bin , at the bottom in this case . The bike is always going to be built to a price , the engine got the full amount of good money , the chassis too , then the running gear , eventually down to some compromised components . Still love the Busa from stock to full mod !!I would wager the R&D would be in the millions over time would it not? I always thought the R&D was the money.
My bike is essentially drag only. While it still has functional lighting and a plate, it's tuned on C16, the forks are cut and ground clearance is minimal. Tire and chassis setup favour straight line performance over everything else. Still got both front rotors, for the reasons I mentioned earlier.If the bike's sole purpose is to drag race and nothing else, one front rotor might be OK, if the bike is going to serve a duel purpose, leave both rotors, it is a heavy bike with gobs of power and one rotor would suffer serious brake fade on the street in my opinion. Suzuki spent millions of dollars and time to sort out the brakes on their bikes for a reason.
My $0.02
Makes sense to me..My bike is essentially drag only. While it still has functional lighting and a plate, it's tuned on C16, the forks are cut and ground clearance is minimal. Tire and chassis setup favour straight line performance over everything else. Still got both front rotors, for the reasons I mentioned earlier.
