My tuner removed mine, I didn't get much of a choice, he is all about performance and anything that blocks air is a bad thing.
I like that tuner you have. Guy makes sense. Do not drop your bike off or else. He does not mess around.
Dragracing...no wheelie bar, leave them in. The bike is smoother to launch and reduces wheelies.
anywhere else... take them out, the lowend hit is vastly changed. Much better wheelies!
For d/racing, you pull them out, you better know how to ride. The engineers know you can't, so that is why they put them in.
<< Since everyone seems to have an opinion, come closer and smell mine. Smells like? Like the throttle is more linear with both working together. The one fly will slow the air just a touch and this is enough of an effect that if you ever owned a CV type carb, they would work perfect if you left them alone as designed.
But you set pods on instead of an air cleaner box with all that slow linear flow, it literally takes a cover shield over the pods to slow the air back down so the fuel could catch up. Yeah, no matter how you fed the fuel, it would just richen up you needed to slow the air speed because the carb just needed a redesign you messing with it. That was/is why the bad reputation/frustration, even today the chopper crowd keep experiencing there mods the hard way.
FI is a different animal. They run open loop and are sensitive to air. So if you remove the flies, you will add more air quicker into the cylinder. The faster your power is handed to you, the easier the wheelie.
Is there a slight lean condition? Yes. At a certain condition; like a fast open throttle. Will it hurt the bike? No. Because it is so momentarily that the secondary is on the open anyway and will feel that stumble away as if was there.
Ordinary street riding, will it hurt the bike? No, the rpm's are slow enough that you feel it rides the same. Just a little peppier on the bottom.
