bradbusa
ok, here's a few pages i scanned over from when we were learning about induction tuning for specific power band and the benefits/affects certain techniques provide.
slide 9 on the first scan talks about throttle body design and construction.
the 2nd scan explains the benefits behind tuning the intake for specific rpm ranges.
longer, smaller diameter runners is similar to our engines when the STP are partially closed. same effect.
larger, shorter diameter runners is what our engines actually have. better high rpm operation.
the STP just simulates smaller diameter by limiting the volume of air flowing into the engine.
the 3rd scan discusses air intake velocity.
basically this all explains in detail that it is possible to tune an engine for peak power in specific areas (high rpm operation vs. lower rpm operation.)
manufacturers are able to get the best of both worlds by using STP, variable length intake ducts, or exhaust valves..
this keeps velocity high at lower engine speeds, and opens to allow more volume at high engine speeds, when velocity is already maintained by piston speed.
hope this makes sense
