michael parris heuberger
Hi. I have the DME mechanical pump. I also have the Robinson HD Out put shaft and outer support bearing. I have over drive 5th and 6th gears a 20 tooth front and a 34 tooth rear also the transmission is all back cut with bilet gearsCurrently using AEM 400lph, probably too powerful... I was using a Chinese copy of 044, with NA setup , stated 300lph (?!). No troubles with that , upgraded when engine was charged. Just to be 'sure' ....
Dropped the engine this evening, just to find the gearbox gremlin
Kinda hoping it's torque issue with driveshaft... 150 lb ft or more from 7000 to 11000rpm... Nothing is wrong or worn , little bit shiny contacts as expected . Engine was used as road bike 30k kilometres (19k miles ) before me.
I ordered a Robinson driveshaft and a support bearing for it. Hopefully it solves the GB issues for good.
Fuel lines are sorted, (not done) but a decent strategy is made. Pressure regulator is hanging the air...
Hoping for a better next year , and season ...
Janne
